L3240 bleeding issue?
/ L3240 bleeding issue? #1
JasG
Veteran Member
CNY
B2650,
A couple weeks ago I noticed that the fuel bowl on my tractor was covered in fuel and very small drips. Never saw this before and about one month before I was mowing some very dusty weeds and the chaff didn't stick. Thought this was kinda funny so I pulled the bowl off. Some how some way this wasn't leaking missing the O-ring that goes between the bowl and the housing. I put every thing back and turned the fuel back on and made sure it would start. I did the bleeding shown in the manual. No problem.
Go the O-ring and put in in today. Went through the bleeding again, this time the tractor is running very rough and keep stalling. I have pulled the bowl and filter off a couple of times and everything seems good, I have fuel flow. Tried beleeding several more times. One time it ran good for about 15-20 second then started running rough and quit again.
Any ideas?
/ L3240 bleeding issue? #2
Have you checked the inner O ring; seems someone had a similar problem not long ago.
Checked the inner for what? It is in place lucky for that.
As I have been going over the drawings I see that not only was the outer O-ring missing, but a spring also that goes under the filter. I thought it was just the inner O-ring that hold it in place, I missed that when I looked it over in the manual.
I have to go to the machinery dealer tomorrow anyway. I think I'm going to buy a new filter and get a spring.
I bought the tractor with 100 hours on it and they told me it was serviced when they took it in. I can understand missing one item but both?
I don't think any harm could come from it due to the filter is up in good shape w/out the spring. O at least it looks that way with the bowl empty of fuel.
/ L3240 bleeding issue? #4
The problem is air being sucked into the
fuel system and a poor seal and then the
tractor will not run properly for you.
/ L3240 bleeding issue? #5
I believe the person posted that he had two inner rings. The inner ring doesn't usually come off with the filter, so he thought there wasn't one and put a second on.
I have extra O rings on hand, but haven't had to use one yet. Without the spring in the bottom, I don't think your fuel will be filtered.
I have a 5030, but it works the same as the L40 models.
Finally got it running after a large amount of messing around with it.
Followed the steps listed from the link below (basically the way I have done other systems) several times and it finally worked. For some reason had a large amount of air in the line for the middle cylinder. Even after I got it running it still ran rough for a few minutes then it seemed to smooth out.
How to Bleed Kubota Fuel Injector Lines | OrangeTractorTalks
2026 Stout TB-76 Tri-Blade Brush Cutter (A64047)
2026 Stout TB-76...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
2013 Komatsu WA320 Wheel Loader (A60352)
2013 Komatsu WA320...
2020 VOLVO VNL760 SLEEPER TRUCK (A59914)
2020 VOLVO VNL760...
John Deere 4040 Tractor (A64047)
John Deere 4040...
2015 John Deere 350G Hydraulic Excavator (A64194)
2015 John Deere...
