L3200 Transmissin Lines
/ L3200 Transmissin Lines #1
Rogerdog
Ferguson TO-30
So I hit a snag with my transmission filter (under the floorboard). It broke off so I had to replace the mounting block. Now I can't get the lines to the block to seal. Based on disassembly, it appears that each line had two o rings and then was pulled into the block with a bolt. The topmost line seals fine but the lower has a leak. Yes, I replaced the o rings as a precaution.
Any tips?
So I hit a snag with my transmission filter (under the floorboard). It broke off so I had to replace the mounting block. Now I can't get the lines to the block to seal. Based on disassembly, it appears that each line had two o rings and then was pulled into the block with a bolt. The topmost line seals fine but the lower has a leak. Yes, I replaced the o rings as a precaution. Any tips?
Never mind. It was actually the ps line and when it hit the snag, it cracked the line as well. The crack was small and it appeared it was leaking from the joint.
Thanks all, back to the parts counter.
/ L3200 Transmissin Lines #3
braze the crack
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
UNUSED IRANCH 15" TOOTHBED MINI EXCAVATOR BUCKET (A60432)
UNUSED IRANCH 15"...
(APPROX. 25) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 25) 4' X...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
Auger Drill Bit (A59228)
Auger Drill Bit...
Gravely ZT 1540 40in Zero Turn Commercial Mower (A59228)
Gravely ZT 1540...
