L3200 Transmissin Lines
   / L3200 Transmissin Lines #1
Rogerdog
Ferguson TO-30
So I hit a snag with my transmission filter (under the floorboard). It broke off so I had to replace the mounting block. Now I can't get the lines to the block to seal. Based on disassembly, it appears that each line had two o rings and then was pulled into the block with a bolt. The topmost line seals fine but the lower has a leak. Yes, I replaced the o rings as a precaution.
Any tips?
So I hit a snag with my transmission filter (under the floorboard). It broke off so I had to replace the mounting block. Now I can't get the lines to the block to seal. Based on disassembly, it appears that each line had two o rings and then was pulled into the block with a bolt. The topmost line seals fine but the lower has a leak. Yes, I replaced the o rings as a precaution. Any tips?
Never mind. It was actually the ps line and when it hit the snag, it cracked the line as well. The crack was small and it appeared it was leaking from the joint.
Thanks all, back to the parts counter.
   / L3200 Transmissin Lines #3
braze the crack
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
CASE TV370B SKID STEER (A51242)
CASE TV370B SKID...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
UNUSED FUTURE DIE CAST RC EXCAVATOR TOY (A51243)
UNUSED FUTURE DIE...
John Deere 2700 5 Bottom Plow (A50514)
John Deere 2700 5...
