L3200 Oil change questions
   / L3200 Oil change questions #1
roaf3x
Bronze Member
Hello all,
After changing the oil in my L3200 I was left with some questions for other operators.
1. The manual calls for 6 US qts. I dumped the oil and put a new filter on.
When I checked this am the level was 1/4 inch above the top hole on the dipstick . Is this normal?
2. I also checked the front axle UDT level. It was low I poured into the higher fill hole until it ran out of the "check "hole . I may have capped it too soon. Can you "overserrvice " the front axle? I dont think I did but I did not know enough about how the thing works to say with confidence.
I think this is the same engine and drivetrain as the L28/34 so I would love to hear any thoughts.
Cheers,
R3
   / L3200 Oil change questions #2
Hello all,
Cheers,
R3
My first thought is on the oil sump, did you remove both drainplugs?
or just one? on the oil level being high.. I have always filled a little and then keep checking the dip stick. After it is full, start it up. run a bit. let it set and check the dipstick, top up as needed.. This prevents overfilling and gets the filter full. Also spec's given in a manual are for a dry engine, not one that has ever been run and may have oil in in the galleys.
James K0UA
I drained both plugs for about 30 minutes. It seemed pretty empty.
Never thought of the dry "quantity" listed in the manual.
Good Stuff !
Cheers,
RD
   / L3200 Oil change questions #4
What K0ua said, and your front axle will be fine.
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
2025 Swict 60in. Bucket Skid Steer Attachment (A50322)
2025 Swict 60in...
John Deere Quick Attach Pallet Forks (A50514)
John Deere Quick...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2014 MACK GU813 GRANITE ROLL OFF TRUCK (A50854)
2014 MACK GU813...
Mayrath 10 x 32 Auger (A50514)
Mayrath 10 x 32...
