L3200 Oil change questions
   / L3200 Oil change questions #1
roaf3x
Hello all,
After changing the oil in my L3200 I was left with some questions for other operators.
1. The manual calls for 6 US qts. I dumped the oil and put a new filter on.
When I checked this am the level was 1/4 inch above the top hole on the dipstick . Is this normal?
2. I also checked the front axle UDT level. It was low I poured into the higher fill hole until it ran out of the "check "hole . I may have capped it too soon. Can you "overserrvice " the front axle? I dont think I did but I did not know enough about how the thing works to say with confidence.
I think this is the same engine and drivetrain as the L28/34 so I would love to hear any thoughts.
Cheers,
R3
   / L3200 Oil change questions #2
Hello all,
Cheers,
R3
My first thought is on the oil sump, did you remove both drainplugs?
or just one? on the oil level being high.. I have always filled a little and then keep checking the dip stick. After it is full, start it up. run a bit. let it set and check the dipstick, top up as needed.. This prevents overfilling and gets the filter full. Also spec's given in a manual are for a dry engine, not one that has ever been run and may have oil in in the galleys.
James K0UA
I drained both plugs for about 30 minutes. It seemed pretty empty.
Never thought of the dry "quantity" listed in the manual.
Good Stuff !
Cheers,
RD
   / L3200 Oil change questions #4
What K0ua said, and your front axle will be fine.
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
(INOPERABLE) CAT D4D (A50854)
(INOPERABLE) CAT...
2023 Komatsu WA320-8 Articulated Wheel Loader (A49461)
2023 Komatsu...
SDLG WHEEL LOADER FORKS MAST W/ 48" FORKS (A51242)
SDLG WHEEL LOADER...
2021 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A50323)
2021 Toyota Tacoma...
2011 KENWORTH T800 (A50854)
2011 KENWORTH T800...
