L3130
   / L3130 #11
Thanks for the reply..........Just trying to get a little info...
   / L3130 #12
I recently purchased a tractor almost exactly the same size as the 3130 and I have 38 acres. I will be doing lots of bushhogging, some loader work, planting garden, and cleaning up in the woods from mess left by Katrina. When I first got it home, I was afraid I'd bought too small. After moving BIG loads of debris with the loader and working some in the woods, power has not been an issue. I run a 5' HD bushhog, and will have a 7' med-hvy duty disc delivered next week. If you need a lot of pto HP, I'd go bigger. If it's not an issue you should be fine. Just MHO.
   / L3130 #13
johnk
Mine is an old Modern BB that I would rate as HD. I have no problem using it although I do lose traction occasionaly in my sandy soil but that is rare. I think it works great.
Vernon
   / L3130 #14
Hey Tex,
What kind of tires you running? r-4's, Ags or Turfs??
   / L3130 #15
johnk
I am running R4s mainly because of prickly pear and other spiney things. Ags and turfs are too vulnerable.
I tried to respond to your PM but it would not go. Said it did not recognize you, hmmmm.
Vernon
   / L3130 #16
I didn't reset all my settings when they revamped the board... Messages should be once again allowed.....I definitely need Ags as its really hilly and gets quite muddy where I am. I groom a lot of trails and some are quite steep. I'll be getting logged as soon as veneer oak goes up again and will have a lot of smoothing out to do.
   / L3130
Thanks for the input. I picked up my L3130 today 7/15/06, I picked up a 72" King Kutter rear discharge finish mower couple of days ago. I would have liked more hp but my dealer that is 6 mi from me is only stocking L 3130 and I got a **** of a deal. I looked up some threads on King Kutter and was nervous about quality, was really nervous as I put it together, but after 4 hours of brutal work, I am very happy with it. As far as the Kubota, man I love it, has plenty of power, and I have run tractors before. Also, there is a debate on transmissions going on now on TractorByNet, my input would be only hydrostatic. It was 90 + degrees today and I still got more done in 4 hours than I usually get done in two days. I also checked the 4 wheel drive out in a wet low ground, it justs unbelievable. I think I used about 4 gallons of fuel, I think I can tell the 4 wheel drive cuts the economy.
   / L3130 #18
I'll be picking up my 3130 Monday or tuesday. I sold my other tractor and implements and this one will be ready for me next week. Pretty excited. I bought the 3130 because I need the weight and traction because my property is hilly and muddy. I got the 723 Loader because the lifting capacity was higher and the money wasn't that much more. I will keep you's posted.......
2019 Doosan DX225LC-5 Excavator (RIDE AND DRIVE) (VERY NICE) (A50774)
2019 Doosan...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
2015 CATERPILLAR 305E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
Wolverine Slide on Manure Forks (A50515)
Wolverine Slide on...
10' Unused Feed Bunk (A50515)
10' Unused Feed...
2001 HAULMARK ELITE II 8' X 24' CARGO TRAILER (A51243)
2001 HAULMARK...
