L3130 vs. L3800
   / L3130 vs. L3800 #1
schaibaa
Cub Cadet GT2544
Hi guys,
I know this isn't a good comparison... but these are my options.
I can get a 2011 50 hour L3800 for $14k. The guy bought the tractor for a contract he had, lost the contract, and needs to sell.
My other choice is a 2005 100 hour L3130 with the LA723 - asking $15k. Both are in excellent condition.
I am mowing 11 acres in the long run, starting with 4 or 5 this year... pulling a disc, that type of thing.
I am thinking the 3130 should be about 12k --
What do you guys suggest? At what price is the 3130 a better deal than the 3800?
Thanks
   / L3130 vs. L3800 #2
You stated that the L3130 had a loader. Does the L3800 have a loader, and if not will you have use for a loader in the future? If you haven't already compared the two models, perhaps you can go to the website TractorData.com and find out some additional info in helping you decide. Good Luck.:tractor:
   / L3130 vs. L3800
Thanks for the follow up.
Yup, I should have specified - the L3800 has the loader. LA524.
I definitely need a loader.
I guess my question is - AFAIK the LA723 is a stronger loader than the LA524.. hard to find exact specs on the LA723.
Am I better served with the LA723 and 7 more HP, or the newer L3800? I think the L3130 would have issues with a 6' cutter... so that does limit me a bit.. but I'd probably only pull a 5'
   / L3130 vs. L3800 #4
The l3130 is much more tractor with a lot more capable loader. In my opinion it is a no brainer in favor of the 3130:thumbsup:
   / L3130 vs. L3800
Ok, thanks for the advice -- even giving up ~7 hp?
Thanks
   / L3130 vs. L3800 #6
Are they both HST?I had a L3130 for four years and 400 hrs.Great machine.Did anything I asked,two bottom plows,six ft. snow plow,5ft.bush-hog,tiller ect.The L3130 is a Grand L..more standard features.Kubota loaders are rated at approximately the number (L723)x 2.2(Kilo) for lift capacity.A 2005 model with 100 hrs is nothing,as new.
   / L3130 vs. L3800 #7
I'm inclined to agree with kuboman as the 3130 is a Grand L vs the L. The Grand L has a superior 3PH, extendable lower links, tilt steering and is a heavier built tractor. I much prefer the steering linkage as well. It is also more likely to have the SSQA, though maybe this one doesn't.
For me at least, the amenities of the Grand L outweighs the extra HP of the 3800, but different strokes...
   / L3130 vs. L3800 #8
I think the 3130 is a much more heavier tractor. Which was a consideration for me. I could not haul it around with my truck. Just something to think about. If I was not hauling my L2800 (same weight as the 3800) I would have traded for the L3130. :thumbsup:
   / L3130 vs. L3800 #9
I'd go with the 3130. Lot beefier machine with the added loader capacity. I may be biased because I have a 3130 but if I had my choice between the 2 it would be hands down for the Grand L...:)
   / L3130 vs. L3800
Thanks for the advice everyone.
I'll work on the 3130.
Aside from independent PTO, tilt steering, extendable 3pt arms, and joystick location, and HD front axle - what are the features in the Grand L?
Not minimizing those features, just trying to get all of the ones I'm aware of out there.
Thanks
Friesen 110 Seed Tender (A50515)
Friesen 110 Seed...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A50323)
2015 Freightliner...
UNUSED FUTURE FT-E48 ELECTRIC BICYCLE (A51244)
UNUSED FUTURE...
John Deere Lawn / Garden Suitcase Weights (A50515)
John Deere Lawn /...
40' High Cube Four Multi Doors Container (A47384)
40' High Cube Four...
2014 JOHN DEERE 35G EXCAVATOR (A51242)
2014 JOHN DEERE...
