L3130 Valve body (Big pics)
   / L3130 Valve body (Big pics) #1
Bill Barrett
Platinum Member
midwest
Kubota L3130, Satoh G650, Case 580, Case 446
Hi all, long time ago I did a thread on installing rear remotes.
http://www.tractorbynet.com/forums/...g/96436-installing-rear-hydraulics-l3130.html
during the install I found the threads under the blank plate bad.
It looked like corrosion or salt water? had set in the threads a ate them out, you can see in the original thread. I told my dealer that two bolts that held seamed to work, but wanted him to know. I thought about a heli coil Heli-Coil ( HeliCoil Inserts ) Helicoils Screw Thread Inserts | Emhart.com for the third bolt, he said no it was under warranty, order what every I needed to take care of the problem, (I wanted to do the repair myself) turned out to be a valve body over 1000 dollars. Also told him I needed the tractor and didn't want to change parts till it was ready for service and filters, that was fine with him.
That was year ago, just got the parts and thought maybe some would like to see inside a tractor with 200 hours.
That was 200 HARD hours, brush mowing up to 2" trees, tilling clay, and such, maybe a little gear grinding.
I was impressed with insides, quality, and lack of any signs of use at all.
   / L3130 Valve body (Big pics) #3
Looks great! But I kind of expected it to. Thanks for sharing--definitely interesting.
MURRAY 22" 2N1 SELF PROPELLED PUSH LAWN MOWER (A51248)
MURRAY 22" 2N1...
JOHN DEERE 5125R LOT NUMBER 24 (A53084)
JOHN DEERE 5125R...
UNUSED RAYSKY RM87-96 MOBILE TOILET (A51248)
UNUSED RAYSKY...
Sany SY35U Pro Mini Excavator (A52384)
Sany SY35U Pro...
DEWALT 3400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 3400 PSI...
Rock wood travel trailer (A51694)
Rock wood travel...
