OP
dangier_VA
Well, found my 3000lb pressure gauge and attached to the quick disconnect on the loader control valve. I have roughly 2700lb pressure available at the loader valve outlet. With that pressure it also tells me that the hydraulic filter and pump are ok. The small (3" x 3/4") hose is a suction line and is not in the loop from the loader control valve to the rear hitch plumbing. It goes from the hst filter to the trans case. I replaced it just due to the hours on the tractor and didn't want to lose all my udt if the hose went.
Still checking.....
David
Still checking.....
David
