L3130 just quit
/ L3130 just quit #1
axpilot
we were spreading fert. on my food plots and it just quit. The plot was rough, and i thought it might me the switch under the seat, but he tested it and it seems to work. when we turn the key all the lights come on but it won't start, it acts like the shuttle shift is in forward or reverse and won't start. Any ideas?
Jake
/ L3130 just quit #2
If your PTO is still engaged the tractor will not start.
/ L3130 just quit
Yea, I have to check that. A friend was driving when this happened. I am going over there today. Also, this is in the wrong section- I should have put it in the Kubota section.
/ L3130 just quit #4
When you say the plot was rough it makes me wonder if you knocked a wire loose ? but also if it is turning over but not getting fuel maybe the bouncing caused some debris in your fuel tank to move through and cause a blockage somewhere but if it is not turning over then I would look for a wire that has been jared loose.
/ L3130 just quit #5
Not sure if your model has electric fuel pump...might be worth checking after all else fails.
/ L3130 just quit
it won't turn over. there is a light on on the dash. it is a picture of a tractor with the pto symbol under it, not the one showing the pto engaged, do you know what that means?
/ L3130 just quit #7
That light is for the mid mounted pto. Does your tractor have one? The tractor thinks the mid pto is turned on.
/ L3130 just quit #8
/ L3130 just quit #9
Had the same problem with Mid PTO light on and no crack at the engine. Checked the fuses and the 5amp mini fuse in the Fuse Panel below the steering column labeled Key Stop was blown. Changed and everything working fine.
I have a Kubota GL4630GSTC.
2025 International MV607 S/A 5/6 Yard Mason Dump Truck (A64194)
2025 International...
New 1.5x27 Ratchet Strap (A65583)
New 1.5x27 Ratchet...
2023 KUBOTA KX040-4 EXCAVATOR (A65053)
2023 KUBOTA...
2008 International 4300 Altec AT40C 34ft. Bucket Truck (A64194)
2008 International...
1500-gallon Poly Tank (A66408)
1500-gallon Poly...
2008 Ford F350 Flatbed (A66408)
2008 Ford F350...
