L3130 HST pedal switch location?
   / L3130 HST pedal switch location? #1
sarinapd
My l3130 isn't kicking over although the electrical system is on, dash is on, glow pug switch clicks over and the pto is disengaged. I noticed one time when I jiggled the hst pedal it kicked over for a second and then nothing. I'm pretty sure the problem must be with the hst pedal switch but I can't seem to find the pedal switch for the life of me. Can anyone make a suggestion? The tractor is a 2004 L3130HST.
All the best,
Pat
   / L3130 HST pedal switch location? #2
First of all, Pat, shell out the hundred bucks for the manual.... lol...:)
Seriously, on page 9-s36.....
Clutch Pedal Switch (for HST Model)
1. Remove the Panel Cover.
2. Disconnect the clutch pedal switch connector (2).
3. Measure the resistance between connector terminals while pushing the clutch pedal switch.
4. If 0 ohm is not indicated, switch is faulty.
If the attached picture didn't uploade correctly, please let me know.... zcowboy001@yahoo.com
Have fun!
Thank you so much Zcowboy. The manual certainly would be beneficial and I'll order up a copy.
Problem solved!
I found that the hst pedal connects via a linkage thru the transmission to the left side of the tractor where a electro-mechanical switch is activated. I loosened the lock nut on the switch and threaded it in closer to the actuator and it now works!
Thanks so much for your help!
Pat
   / L3130 HST pedal switch location? #4
Glad to have helped....
I just got a second hand 2005 L3130 this past August. Went a little over 30 hours myself; with the total now being 152.... Mostly moving firewood logs and repositioning my rock walls.
A novice myself, any help I can offer, feel free to email directly.
God bless,
Wei
   / L3130 HST pedal switch location? #5
PS....
Pat,
Don't know how much you plan to work on your tractor on your own.... perhaps a parts manual wouldn't be a bad idea either...
Just another 2 cents....
W
Thanks so much. Spent the weekend completely going thru the tractor, changed all filters & fluids, pressure washed it. It looks and runs great!
All the best,
Pat
   / L3130 HST pedal switch location? #8
Since I traded in my L3130 and got my L5740, I still have the WSM manual for it. If any one is intrested, PM me.
2019 Freightliner 122SD, Cummins X15 (A52384)
2019 Freightliner...
2021 ALLMAND BROS, INC. NIGHT LITE LIGHT TOWER (A52472)
2021 ALLMAND BROS...
2012 Ram 3500 Crew Cab Flat Bed Truck (A50323)
2012 Ram 3500 Crew...
2016 Dodge Caravan Van (A50324)
2016 Dodge Caravan...
2015 HINO CONVENTIONAL TYPE TRUCK (A52472)
2015 HINO...
Set of AG R4 Wheels and Tires (A52748)
Set of AG R4...
