L3130 brake warning lamp
   / L3130 brake warning lamp #1
big e
outside columbus, ohio
L3130 Kubota
On the L3130, does the brake warning lamp tell you when the brakes FAIL? Or does it tell you when the parking brakes are ON?
I have a sneaking suspesion that warning lamp is for when they fail, which is a bummer because I have a terrible track record of remembering to take off the brakes. With all the onboard electronics and whistles and bells that I don't use/need, I am dismayed that there is no warning light for when brakes are locked on. It is SO easy to drive off with the brakes locked on (for me at least).
   / L3130 brake warning lamp #2
On my L4330, the brake light is only on when the parking brake is on.
   / L3130 brake warning lamp #3
On my Kubota Grand L3830 the brake light is ON when the parking brake is ON. I would imagine your's will operate the same way. Maybe your bulb is burned out or the switch is out of adjustment. Or you are not depressing the brake far enough when putting the parking brake on. :steeringwheel:
There's no mechanism to detect "failed brakes" that I'm aware of.
That is great to know. And now I'm not recalling if the brake bulb lights up briefly when the key is switched to "on". I'll check it. I'd like to get that bulb to work... driving with the brakes on p*sses me off!
   / L3130 brake warning lamp #5
Same way with my old L5030.
Glad to know I'm not alone on that!
   / L3130 brake warning lamp #7
Friend of mine owns a 3130. We swap tractors sometimes. Light is on when brakes are on!
Deano
Thanks, glad to hear that.
Hope to look at the bulb tomorrow... otherwise it will be put back a week or so. Headed to the beach!
   / L3130 brake warning lamp #9
Mine quit for quite awhile. Seems to me that the arm that causes the switch to close is connected to the brake pedal linkage under the dash. I recall having to bend it back into place to get mine to work again.
HYSTER S50FT STRAIGHT MAST FORKLIFT (A51242)
HYSTER S50FT...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
Rears 500 Gallon Orchard Sprayer (A50120)
Rears 500 Gallon...
DIRT DOG RC104 4' ROTARY MOWER (A51243)
DIRT DOG RC104 4'...
2015 CATERPILLAR TL1055C TELESCOPIC FORKLIFT (A51242)
2015 CATERPILLAR...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
