L305 rear lift capacity
   / L305 rear lift capacity #1
Oakley
2002 Kubota BX2200
I'm looking for a bigger tractor than my BX2200 to tackle the jungle at my mother's property and to move 1300 lb round bales. Can't find the lift capacity on this model. Anyone know? Thanks.
   / L305 rear lift capacity #2
I would say about judging at models near it in the same model year, ~1500 lbs @ ends and ~750 @ 24" back.
For comparison the BX2200 can lift ~1200 @ ends, ~650 @ 24" back.
Again, these numbers are conservative. Each machine will vary on the hydraulic age, and pressure settings.
   / L305 rear lift capacity #3
Keep in mind if you are using a 3 pt bale spear or rear mount forks to move the bales, the center of mass of the bale will be to the rear of the lift point. This means the tractor lift capacity needs to be considerably higher than the weight of the bale. As diesel85 points out, you need to look at the rating 24" back of the lift point.
   / L305 rear lift capacity #4
Not to mention, if you start putting heavy stuff in the rear, you'll need a front ballast. Same way you'd need a rear ballast for a FEL.
It's all about keeping everything evenly distributed.
Will definitely have weights on front, had a tray built for the BX, because the box blade would actually cause me to lose traction at the front tires. Need my old MF135 for this mess.
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
FRONTIER CA2072 LOT NUMBER 41 (A53084)
FRONTIER CA2072...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
2002 Fleetwood Expedition 36ft Class A Motorhome (A51694)
2002 Fleetwood...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
