L3010 vs. ASVI RC-30
   / L3010 vs. ASVI RC-30 #1
Anonymous Poster
Epic Contributor
Finally thinking about replacing my old 18 horse PowerKing. I have been following the posts on this board for some time and it looks like the L3010 or L3410 will work for me. I have about 8 acres to rough mow, some landscaping, and 2 miles of cross-country ski trails to maintain. The trails are in rough shape -lots of rocks and uneven ground. Recently, I came across a different type of machine, a 30 horse tracked vehicle made by ASVI http://www.asvi.com/Products/RC_30/rc_30.html . I'm wondering if any of you out there have any opinions on this type of machine and how it might stack up against the Kubota (reliability is a strong selling point for me). The RC-30 would seem to have the advantage in the woods and it can run a flail mower. Any thoughts from the veterans would be appreciated.
   / L3010 vs. ASVI RC-30 #2
Boy, another great little toy!! (Ahem, I mean tool......) The only comment I would make is trying to use a tracked machine for moving long distances. A friend who is very knowledgeable about heavy equipment (used to teach it for a living) told me tracked vehicles aren't good to use for traveling long distances. If you have miles of trails and a lot of land to mow I don't think a tracked vehicle would be the way to go. Tracks will wear out after less miles than a comparable set of tires and I don't want to know what a set of tracks cost. Usually tracked vehicles are used for very soft or inaccesible area's (power line companies use them a lot) but that benefit is reduced if you are already on "finished" land as you described.
   / L3010 vs. ASVI RC-30 #3
Northern Dave,
Interesting machine. Looks like a skid steer with a high track. I would think it would tear up the turf on every turn. Have a feeling that when the ground is wet you would do as much damage, then you could buy a tractor to fix the damage. You may be on to something.
Thanks much to gerard and MarkV for their insights. I was expecting something like this, since I have seen few glowing recommendations for tracked machines. My impression is that they can be taken into wet or rough areas where a tractor can't go, but that overall their disadvantages usually outweigh their advantages, especially if you can only afford one machine. Back to Kubota.
Man, you guys are way off base, 180 degrees as a matter of fact. The RC 30 does lesss damage to the grass than a tractor even when turning! and as for traveling, this is not a steel tracked crawler!! Steel tracks with steel sprockets wear out due to speed and distance. The RC 30 has a rubber track with an internal positive drive - like a snowmobile, every here of a modern snomobile track wearing out..not likely, and they go a 100 mph. The RC has alot less ground pressure than you walking, that is why it is amazingly gentle to lawns, sod, turf, wet or dry. I use the RC to repair damage my tractor leaves!!! Don't compare my RC to an old dumpy steel cleated beast it is nothing like that. Drive one, you'll see what I mean.
F.R.T
   / L3010 vs. ASVI RC-30 #6
they may be a good machine, but there web site sure is slow to generate the screen. Must be all those .gif's
FRT (RC30 owner), I wonder if you could tell us what you use your machine for and some of its strong and weak points. I apologize for asking this question on the Kubota buying forum, but I think that many Kubota owners/buyers might also find this interesting.
   / L3010 vs. ASVI RC-30 #8
i am a sales rep for both Kubota and ASV RC-30. These are two different types of machines. they both have there advantages and disadvantages. Long day sure sounding like a sale rep. However, we sold an RC-30 today. Reply to me with any questions I would be happy to assist you.
Kenco PH9000 Self-Leveling Pipe Hook - 9,000 LB Capacity, 8FT Max Pipe Length (A51039)
Kenco PH9000...
500 gal Fuel Barrel with Pump (A50515)
500 gal Fuel...
2022 Ford F-550 Cab and Chassis Truck (A50323)
2022 Ford F-550...
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A51039)
Hay Van FL-95 Bale...
Land Honor Quick Attach Bale Spear (A50515)
Land Honor Quick...
John Deere 893 Corn Head (A50514)
John Deere 893...
