L3010 Squeal
   / L3010 Squeal #1
Anonymous Poster
Epic Contributor
I have a L3010 Hydro that has an intermittent high pitch squeal at idle while sitting still. It did it since it was brand new. Doesn't seem to be related to anything. Does it for a couple of seconds then a few minutes later for no reason does it again. Almost sounds like a dry rubber seal or bushing. Machine has 40 hrs on it. Noise not getting worse of better.
   / L3010 Squeal #2
Mine did it when it was new also. I changed to the Super UDT at 50 hours and I haven't noticed it since. Maybe changing the fluid did it or maybe just the hours...or maybe something else.
I had my dealer listen to it and he said it was normal.
   / L3010 Squeal #3
Can you tell the general location of where the sound is coming from? Belts tensioned okay? The Hydro fluid level is okay in the sight glass?
Pete and Clementine (L3010HSD)
   / L3010 Squeal
It seems to be coming from the mid to rear of the tractor. Only does it when the clutch is out. Happens a few times a day. Hoping it would go away after I had some hours on it. Belts and fluid all ok.
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51694)
2006 iDrive...
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
2011 4300M7 International (Pavo, GA) (A50123)
2011 4300M7...
1999 Caterpillar TH63 (A50123)
1999 Caterpillar...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
2016 Tesla Model S 85D Long Range AWD Sedan (A51694)
2016 Tesla Model S...
