L3010 PTO Chipper
   / L3010 PTO Chipper #1
moot
Georgia
Kubota L3010
   / L3010 PTO Chipper
Thanks. I was only planning on running 6" max. through the 8" chipper.
Do you happen to know the hp @ the pto of the L3010?
Can you recommend a chipper that will work well with the L3010?
   / L3010 PTO Chipper #4
If you clicked on my Tractor Data link in the post above it has the info.
I will repeat it here -
Tractor power:
Engine:30 hp [22.4 kW]
PTO (rated):25.5 hp [19.0 kW]
With only 25 at the PTO I think 6 inch material would probably stall the tractor. If the chipper has a controlled automatic feed you may be ok as that should enable you to stop the feed when the tractor RPM's come down.
Vermeer 502 Towable Stump Grinder (A50774)
Vermeer 502...
2007 John Deere CT332 Skidloader (RIDE AND DRIVE) (A50774)
2007 John Deere...
2009 MINI Cooper Coupe (A50324)
2009 MINI Cooper...
2016 Peterbilt 567 Tri-Axle Dump Truck (A50323)
2016 Peterbilt 567...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
Airco Tig Welder (A51691)
Airco Tig Welder...
