L3010 HST - Cleaning the Transmission Strainer
   / L3010 HST - Cleaning the Transmission Strainer #1
fernbank_bound
Kubota L3010
My users manual says use a "nonflammable solvent" to clean the transmission strainer. What is a good choice of solvent?
   / L3010 HST - Cleaning the Transmission Strainer #2
Even though diesel fuel is flameable that is what I would use, it is a great cleaner. I think that the non-flamable part is for your saftey. Just be sure to blow it dry if you have compressed air.
   / L3010 HST - Cleaning the Transmission Strainer #3
Like Deerlope said or use a brake/parts spray cleaner like Permatex. My strainer was hard to remove and luckily was clean of shavings. Don't have to worry about it on the 3130..
   / L3010 HST - Cleaning the Transmission Strainer #4
Right or wrong, I use wd40, (I believe it's flammable....)
   / L3010 HST - Cleaning the Transmission Strainer #5
I used engine degreaser to clean the strainer on my JD. For the life of me I don't know WHAT would be a nonflammable solvent...
   / L3010 HST - Cleaning the Transmission Strainer #6
I use carb cleaner quite often for most all cleaning jobs. I think they are just being cautious.
Thanks for all the responses. I got a hold of a local Kubota dealer and he said that the "nonflammable" recommendation is for your own safety. They just don't want you using gasoline and blowing yourself up. He recommended kerosene (which is not a whole lot different from diesel fuel from what I understand). It seemed to work fine. I used the kerosene to clean the fuel filter as well.
480/70R38 LOT NUMBER 135 (A53084)
480/70R38 LOT...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
2024 CATERPILLAR 255 SKID STEER (A51246)
2024 CATERPILLAR...
2000 Ford F-150 Pickup Truck, VIN # 1FTRX17W7YNA75070 (A51572)
2000 Ford F-150...
2015 Jeep Wrangler Unlimited Sport 4x4 SUV (A51694)
2015 Jeep Wrangler...
2008 Chevrolet Trailblazer SUV (A51694)
2008 Chevrolet...
