L3010 HST - Cleaning the Transmission Strainer
   / L3010 HST - Cleaning the Transmission Strainer #1
fernbank_bound
Kubota L3010
My users manual says use a "nonflammable solvent" to clean the transmission strainer. What is a good choice of solvent?
   / L3010 HST - Cleaning the Transmission Strainer #2
Even though diesel fuel is flameable that is what I would use, it is a great cleaner. I think that the non-flamable part is for your saftey. Just be sure to blow it dry if you have compressed air.
   / L3010 HST - Cleaning the Transmission Strainer #3
Like Deerlope said or use a brake/parts spray cleaner like Permatex. My strainer was hard to remove and luckily was clean of shavings. Don't have to worry about it on the 3130..
   / L3010 HST - Cleaning the Transmission Strainer #4
Right or wrong, I use wd40, (I believe it's flammable....)
   / L3010 HST - Cleaning the Transmission Strainer #5
I used engine degreaser to clean the strainer on my JD. For the life of me I don't know WHAT would be a nonflammable solvent...
   / L3010 HST - Cleaning the Transmission Strainer #6
I use carb cleaner quite often for most all cleaning jobs. I think they are just being cautious.
Thanks for all the responses. I got a hold of a local Kubota dealer and he said that the "nonflammable" recommendation is for your own safety. They just don't want you using gasoline and blowing yourself up. He recommended kerosene (which is not a whole lot different from diesel fuel from what I understand). It seemed to work fine. I used the kerosene to clean the fuel filter as well.
Orico 3000 Cook Top (A51573)
Orico 3000 Cook...
2013 WESTERN CONSTRUCTION COMPONENTS BELLY DUMP TRAILER (A52472)
2013 WESTERN...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A51573)
New/Unused AGT...
2005 Northwood Artic Fox 29V T/A 34ft. 5th Wheel Travel Trailer (A51694)
2005 Northwood...
2013 John Deere Gator 825E (A51573)
2013 John Deere...
40' CONTAINER (A51244)
