L3010 glow plugs
/ L3010 glow plugs #1
liam
I have a 2000 L3010 gst and my glow plug part # is NGK Y713R. I can't find any information anywhere on this plug. Can you help?
/ L3010 glow plugs #2
Can your local Kubota dealer help? Always the best bet to check with your dealer first, don't you think?
/ L3010 glow plugs
Thanks Roy,
But it is Sunday and nobody is open thanks for the info
/ L3010 glow plugs #4
Oops!!!!!!
True, it is Sunday!
Anyway, I did a search for those NGK glowplugs, but the 713 number wasn't listed. There was a 712 and 715 though.
So, I reckon the 713 plug may be superceded.
Just being nosy, why do you need info on glowplugs on this fine Sunday?
/ L3010 glow plugs #5
Roy:
I'd bet his fire is out and he has some projects to handle. Problem is, I have never had to replace a glow plug in any Kubota I have ever owned. What gives??
/ L3010 glow plugs
well we're coming to conclusions...reply if anything to add.
1 month ago we got really bad diesel.
replaced filter and gas...all was fine.
saturday glow plug fowled...1/4" chip of plug gone
we get compression and are going to flush the oil system
anything else we should check?
P.S. Found glow plug...3 days out and $45 a piece!
P.S.S. Roy, I hope I didn't tick you off...jobs to get done and no tractor to do it
/ L3010 glow plugs #7
I wonder what cylinder got that piece of the glow plug? /forums/images/graemlins/shocked.gif It had to go some where thru the upper end of the engine! /forums/images/graemlins/confused.gif If lucky out the exhaust valve!
/ L3010 glow plugs #8
"P.S.S. Roy, I hope I didn't tick you off...jobs to get done and no tractor to do it "
Nah..I was the one out of line...
Boy, $45 each! Of course, they don't go bad too often. Just a pain when they do.
/ L3010 glow plugs #9
<font color="blue"> ...jobs to get done and no tractor to do it </font>
Liam,
I'm /forums/images/graemlins/confused.gif.
Are you saying that your tractor would not start on two glow plugs, or is it that somehow all three [I assume 3 cylinders] are bad?
Did you check to make sure voltage is getting to the glow plugs?
Or is it that with the one broken plug, you don't want to risk running the tractor with that chipped plug in place? I guess that is probably the answer... /forums/images/graemlins/shocked.gif
Now that I answered my own question, I will post this just in case I am wrong... /forums/images/graemlins/blush.gif
/ L3010 glow plugs #10
Liam:
I hope you mean bad diesel not gas. I still don't understand the chipped glow plug. Something had to chip it. Bad diesel or not, the only thing to go in a combustion chamber are diesel through the injector and air through the air filter and manifold. About the only way the glow plug could fail would be a really extended pre-heat which would destroy the tip. In that case, replace all of them. I don't want to sound accusing, but did you in the effort of starting the engine on bad diesel extend the pre-heat cycle considerably?? If you did, again, I'd replace all of them. You didn't use either?? That is a no-no. Please elaborate. /forums/images/graemlins/confused.gif We are all curious, especially Henro.
/ L3010 glow plugs
been a busy week, I'm going to replace the oil this weekend and look for any fragments. Henro...I tend to use the words "diesel and gas" universally...but I do mean diesel. I'm not sure how the plug chipped yet but the "diesel" I pulled out of it a few weeks back was horrible looking. A lot of water must have gotten into the gas stations tanks...the diesel could have been milk the way it looked. I'll let you know the updates at the end of the weekend.
Thanks for all the info!
Liam
/ L3010 glow plugs #12
I don't know if your Bota has a pre chamber or not. If you have the prechamber you can remove the injector and fish out the end of the glow plug. Glow Plugs will fracture and break when over heated. Could be the other two were open and it allowed to much amprage to the one that was left and it blew. I have changed many glow plugs in autos and trucks and had good luck with a long pair of tweesers to fish out the broken tip. If you do not have a prechamber the tip is more than likley imbeded in the top of the piston.
RIDGID AIR COMPRESSOR (A65643)
RIDGID AIR...
LOOK! (A63109)
LOOK! (A63109)
New Holland 273 Square Baler (A66408)
New Holland 273...
TR 23 QA Mini Trencher (A64127)
TR 23 QA Mini...
Decorative Bell (A64127)
Decorative Bell...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
