L3010 BLOCK HEATER
/ L3010 BLOCK HEATER #1
Anonymous Poster
Epic Contributor
I recently purchased and installed a Kubota B/H (P#70000-92500),into my L3010.The kit consisted of metal bushing,a 400W heater element,and a weather proof 7" power cord with locking nut. The bushing has a .013" taper on one end that is inserted into a vacated frost plug hole. The other end has internal threads,that are used to accommodate the heater assy. The heater assy. as mentioned earlier is 400W type with threads on one end,and terminals to accept the cord assy.,on the other. The cord assy,. has push on terminals held in place by a nut. The instructions,written for many different eng. styles,suggested picking a frost plug about mid engined.My engine,being a three cylinder,made the choice easy.I started by removing side panel,grill assy.,drained collant,for access I also removed the starter.Plug removal was not that difficult.I first drilled two 1/4" holes into the center of the plug,then used a tapered drift pin to pop it out.After cleaning out the hole,I used locktite around the tapered end,and tapped into place.The threads of the heater assy.,were then coated with teflon tape and screwed into place.The cord assy.,was then pushed on,and secured with locknut.Put all back together,no leaks,works great.
/ L3010 BLOCK HEATER #3
botaman2: ...That's a nicely documented installation. /forums/images/graemlins/cool.gif Hope to hear more from you in the future. new member. /forums/images/graemlins/grin.gif /forums/images/graemlins/wink.gif ..Raybee <font color="red"> </font>
/ L3010 BLOCK HEATER #4
Thanks for the description. What did the heater cost? I guess I could figure it out but what side of the engine: drivers side or, uh, drivers side? /forums/images/graemlins/tongue.gif
Sorry!I took so long to respond. Sitting in the drivers seat facing forward, I installed the heater on the left side of the engine.The cost with a $5.00 s/h was $51.45. from TractorSmart.com.
2016 FORD F-250 (A63569)
2016 FORD F-250...
John Deere 2750 Tractor (A64047)
John Deere 2750...
2013 John Deere 8360RT Track Tractor (A63109)
2013 John Deere...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A62130)
2012 VOLVO DBL...
