L3000 delivered! Grrr!
   / L3000 delivered! Grrr! #11
To post the link that you typed in your posting, you would type it like this - [<font color=red>"</font color=red>url=http://carverequipment.com/l2600_l3000_standard_equipment.htm]Carver[/url<font color=red>"</font color=red>] - but DO NOT include the red quote marks at the beginning or the end. Then it will look like this - <A target="_blank" HREF=http://carverequipment.com/l2600_l3000_standard_equipment.htm> Carver</A>. You can find this information in the FAQ section at the top of the page.
   / L3000 delivered! Grrr! #12
Rick -
I don't know what to say about Carver's information. Fer sure at the time I was tractor shopping (about a year and a half ago), there were no armrests on any of the L3000's I looked at, and the brochure shows the exact same seat as in the picture I posted.
I suppose it's possible that Kubota has ugraded the seat recently, or maybe Carver does it as part of their own dealer prep. You can always email Steve Carver (steve@carverequipment.com) and ask him. He'll answer you in a timely fashion. It's even possible his web page is in error (hey -- it happens to the best of 'em
You might also want to contact <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/searchmembers.pl?action=search&search=L3000&by=tractor>these guys</A> with a private message or email, since they all own L3000's.
Oh, and about making links active in a message -- check the <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/faq_english.pl?Cat=#markup>FAQ</A> about using the [/b] or [b][url=][/b] tags. [img]/w...wice. [img]/w3tcompact/icons/laugh.gif[/img])
   / L3000 delivered! Grrr! #13
W/Regards to the diff lock, pressing it while the tractor is in motion is totally different than pressing it while a tire is spinning. If one tire is spinning, the other is likely not turning at all. Therefore, twice the rotational speed is going to the spinning tire. Just like Treeboone said, stomping on the lock when spinning might do quite a bit of damage. You might get away with it a few times, but after while the locking mechanism is not going to take it. If you see you are going into a place that will need it, stomp on it prior to traction loss. If things have already gone south, stop the tractor, stomp on it, then take off again.
It will likely stay engaged from the strain until traction improves. If it hasn't released once traction improves, weave back and forth a bit with the steering wheel. It will release quite quickly. Also, you won't be able to turn until it does release.
Hope this helps,
Nick
   / L3000 delivered! Grrr! #14
Thanks for the inormation...it is much appreciated. Fortunately with 4WD I have never had to use this feature. On my previous 2WD tractors I stomped on it all the time!! I'm sure I abused it in the past but luckily never had a problem. One of the many reasons I love/w3tcompact/icons/love.gif 4WD!
   / L3000 delivered! Grrr! #15
SIR,
it appears your rear wheels are out as far as they will go. this is good. when i got
my L3000DT the wheels were all the way in, and it is a job to switch them. my
suggestion would be to mount wheel weights, using the hackers plan. this is what
i did, and it sure makes a difference. if i can ever collect my thoughts, i will try to
make a drawing of the plate that i used for my weights, and if i can find out how,
i will post this, for everyone to use. one other thing, i bought the tractor manual.
i paid $60.00 for it, and it has a lot of good stuff in it.
enjoy your new tractor.
accordionman
william l. brown
   / L3000 delivered! Grrr! #16
Rick,
I think the differential lock petal has been explained well but I doubt that you ever need it with the 4wd.
The knob under the seat that says <open-closed> as David said slows the descent of the implement on your 3ph. I leave mine open all of the time. When I first got my tractor mine was almost impossible to turn too. I got it to turn a little, put some oil on it and turned it back and forth till it got fairly easy to turn. I then turned it to the wide open position and left it.
I had an old IH444 that had very poor (worn out) hydraulics. When you were carrying an implement up in the transport mode, it took all of the hydraulics to hold it up and the power steering was starved to the point it was very hard to steer. If I was going far, I would close off the valve after I got it raised. That way the hydraulic pump would be sending all of its flow to my steering.
I'm not sure if the L3000 has a seperate pump for the steering but if it doesn't you might remember this tip. It'll probably be 40 or 50 years before you need it thought.
I'm also not positive about the arm rests but there were a couple on my dealer's lot when I bought mine and I'm pretty sure they didn't have them.
As far as the tractor not looking new most dealers subscribe to the "first in - first out" theory. I think that their inventory costs them more money the longer it stays on the lot. Naturally they want to keep the "lot time" down to a minimum. Also the pretty shiny one looks better to potential customers.
There was another thread about someone who picked out a specific tractor and the dealer was going to substitute it for another one that had been there for a while. The best thing to do (and I know it's too late now) is to write the serial number of the one that you want on the contract, on your check and anything else that passes between you and the dealer prior to delivery.
As someone else said tell the dealer you expect a can of can of Kubota orange and Kubota grey to go with your new toy (I mean tractor). You will get a lot of satisfaction out of going around taking care of little scuffs and rusty spots.
Also I wouldn't admit it anywhere else except on this board but I <font color=red>wax</font color=red> my tractor. After you get the touchups done, put you a good coat of the best automotive wax you can get on the sheet metal. A tractor is exposed to dirt, dust and mud much more than most automobiles so it just makes sense to protect it as much as you can.
Best of luck with your new tractor and I hope you enjoy it as much as I do mine.
TBone
   / L3000 delivered! Grrr! #17
<font color=blue>I doubt that you ever need it with the 4wd</font color=blue>
I guess it depends on your terrain, soil conditions and the particular chores you're trying to do, TBone. I have 4wd, and the diff lock has gotten me out of jams more than once.
   / L3000 delivered! Grrr! #18
Rick, you were good to reply to me about L3000DT's. So here goes, I have been from Amarillo to Oklahoma City looking for the best deal on one. I have never seen armrests on a L3000 yet. I have never owned a new tractor either. Do not let the scuff marks get you down. I know that you wanted it perfect, but a tractor is made to be used. Enjoy and use it. Bob
   / L3000 delivered! Grrr! #19
rick: congrats on the new tractor and welcome to the forum. form wht i understand the diff. lock should only e depressed whe the wheels are not spinning,and only when u are not trying to turn.the knob in fornt of the seat is to slow down the lowering of the 3 pt. as for the seat and rust spots u may have taken delivery of a tractor that is new but maybey sitting on the lot for a while.if it is an older model i would think the dealer should have made that clear to u, if he did not shame on him!
   / L3000 delivered! Grrr! #20
Rick, I have an L3000 I bought about a year ago, I have never seen one with armrests and mine does'nt have them either(dang it). I love my tractor, it is my first new anything, I do use it hard and it has many sratches now plus a few dings. I live in very rough area and the diff. lock has saved my bacon even fully loaded in four wheel drive, my tractors differential lock will not engage unless the wheels are moving, if I stop to engage it ,the pedal won't depress until I go forward or backward about a quarter of a revolution.
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58216)
HYDRAULIC THUMB...
2023 Kubota KX057-5 Compact Excavator (A56436)
2023 Kubota...
ROLLING METAL RANK & CONTENTS (A58374)
ROLLING METAL RANK...
1993 CHEVROLET TOP KICK KODIAK DUMP TRUCK (A52708)
1993 CHEVROLET TOP...
3PT SCRAPE BLADE W/ TEETH (A58374)
3PT SCRAPE BLADE...
2009 MULTIQUIP 25KW GENERATOR (A55745)
2009 MULTIQUIP...
