L3000 block heater installation
/ L3000 block heater installation #1
cp1969
Kansas
Kubota L3000DT
I bought a block heater at the end of last winter and never got around to installing it.
It is the kind that replaces a freeze plug--the only question is, which one? IIRC, the instructions said the one that's basically covered up by the starter. There is another one toward the middle or front of the block that looks wide open (easy to get to).
Any reason why this location should not be used?
Thanks.
/ L3000 block heater installation #2
No reason it can't be used - any convenient freeze plug is ok. There is a description here of the installation of a freeze plug block heater. Have fun /forums/images/graemlins/cool.gif
Thanks for the link to your installation description. That will help a lot, I really appreciate it.
I will probably try to undertake that little operation sometime soon. I'll post if I run into anything unusual.
90in. Work Bench (A65640)
90in. Work Bench...
2018 HINO 338 4X2 S/A 26FT FLATBED (A59912)
2018 HINO 338 4X2...
ATS ATS-PC90 Heavy Duty Plate Compactor (A62679)
ATS ATS-PC90 Heavy...
New/Unused Landhonor Tree/Post Puller (A65583)
New/Unused...
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A60352)
Okada OKB 304B...
