L3000 3PT Lift Problem
   / L3000 3PT Lift Problem #1
trudie1
Michigan
Kubota L3000DT
Have an L3000 that the 3 point won't lift unless I roll the FEL up. Started right after I had a hydraulic feed line leak and replaced both the feed and return. Tried swapping them still no luck. Any ideas???
   / L3000 3PT Lift Problem #2
Check the power beyond port from your loader valve - it is supposed to feed the top cover and it sounds like you crossed two lines. The other one is the return line so the loader will come down with the engine running.
By holding the loader on demand, you are plugging the leak that is going back to tank. With the loader in neutral, it is easier for the fluid to go to tank than on to the hitch and do the hard work.
Good luck!
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2014 TROXELL KILL/TRANSPORT TRAILER (A50854)
2014 TROXELL...
Kioti DK45 Tractor (A50860)
Kioti DK45 Tractor...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2016 KUBOTA SVL95-2S TRACK LOADER (A50854)
2016 KUBOTA...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
