L295DT Tachometer stopped working
   / L295DT Tachometer stopped working #1
gunslinger69
kubota 295dt
The tachometer on my 1980 L295DT has stopped working. The arrow on the gauge does not move when the engine is operating. I checked the connection on the back of gauge and it appears to be secure. Any ideas on what could be causing it? I have been using the tractor for a year using the engine sound as my gauge.
   / L295DT Tachometer stopped working #2
There's a black flexible cable running from the back of the dash out to the right front corner of the engine. The core usually breaks a couple inches from where it goes into the engine. A new cable is part number 35300-34650 and costs about $30. Can order from tractorsmart.com or local dealer.
   / L295DT Tachometer stopped working #3
Yep. It's probably the cable. The cable connects to front of the engine to the hour meter drive that spins in sync with the fuel camshaft. On my B8600, both the cable and the engine connection was broken. If you disconnect the cable from the dash meter, you should see the center of the cable spinning with the engine running. Probably won't be. If you then disconnect the other end of the cable from the engine, with a flashlight you should see a little flat thing spinning inside the engine connection when the engine is running. If the engine connection is spinning and the gauge side of the cable wasn't spinning in the first experiment, then you know the cable only is bad. If the engine side is not spinning, then you need to replace the hour meter drive on the engine. Cable could also be bad and you can test that by grabbing both sides with needle nose pliers and seeing if they are connected.
   / L295DT Tachometer stopped working #4
Do you know if he drawing for the hour meter drive in on the camshaft parts drawing?
   / L295DT Tachometer stopped working #5
No, it's on the gear case diagram, the engine front cover.
Thanks everyone,
Now I have a plan and directions for something to focus on. This forum is a great resource.............Gunslinger
   / L295DT Tachometer stopped working #8
I have a 1977 Kubota L-185DT and the tachometer spins when the engine runs. The higher the RPM the faster it spins. Is this just the cable or the tachometer broken. Any thoughts?
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2015 FREIGHTLINER...
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
2011 Nissan Titan SV 4x4 Crew Cab Pickup Truck (A50323)
2011 Nissan Titan...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
John Deere 922 Platform (A50514)
John Deere 922...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
