L2950 - Broke 3PH Lift while stump-pulling
   / L2950 - Broke 3PH Lift while stump-pulling #1
AltaNet
After manually digging out the majority of an oak root cluster and sawing through the primary roots, I chained-up to my gearmore box to pull the stump. After tensioning and rocking a few times, I heard a heat-sinking clank and the box dropped. My local Kubota shop says I probably sheared the internal lift-arm (hitch-rod?), just under the seat pan. There are no external signs of beakage or leaking. With the box removed, the two arms move up/down freely with no sounds coming from within. The elevation lever does nothing. The 3PH does not have the drafting feature.
I've had the 2950 for about six years, but I typically use it for snowblowing and occasional property maintenance; this is the first major problem I've had and I have some questions about getting it repaired:
1) Does anyone have an idea of how bad/expensive the damage could be? What is the name of the part that I would have broken?
2) Is this something that I might be able to repair myself? I gather that the fender(s) and seat-pan will have to come off to get to the top housing of the assembly. I see a gasket between the upper housing and the gear-box that will need replacement.
3) What are the chances that I actually broke whatever the internal hydraulic arm is anchored to inside the housing?
4) How far out of reasonable operation was I? Clearly, the downwards pressure on the box was high, but I didn't expect the traction to exceed the capability of a critical internal component.
5) Could there be loose pieces that would drop into more sensitive areas? How should I move the tractor onto a trailer?
6) Aside from "don't do that again", is there a way to prevent this from happening again? How do you know when you are nearing a break-point? I thought I read in the mesasge boards about some kind of excess pressure valve for the 3PH.
Thanks much for your help
   / L2950 - Broke 3PH Lift while stump-pulling #2
"some kind of excess pressure valve for the 3PH"
I believe this relief valve is active when you are trying to lift something heavier then the 3pt will allow.. if the 3pt is already lifted.. it is kinda locked in place.. the relief valve would activate only when lifting or lowering the 3pt.
For pulling/skidding logs.. I always use the drawbar that is attached to the bottom of the differential.
Someone else had a post where they broke off the entire 3pt plate off the back of the tractor. Sorry about your tractor.. probably not an easy fix..
   / L2950 - Broke 3PH Lift while stump-pulling #3
My recommendation would be to let your Kubota dealer's trained technicians make this repair. Hopefully the repair is something simple, but if not I would want an expert making the repair.
My father would call unfortunate experiences such as yours life's tuition. Sometimes it can be costly.
Good luck!
OrangeGuy
   / L2950 - Broke 3PH Lift while stump-pulling #4
This is probably not the information that you wanted to hear but I agree that a repair of this nature might best be left up to your local dealer.
Whenever pulling heavy loads I always use the drawbar since it puts the load below the rear axle and it less likely to break.
Sorry that you are having problems with your rig. /forums/images/graemlins/frown.gif
   / L2950 - Broke 3PH Lift while stump-pulling #5
Don't have a bota but you probably broke rod/bracket that actuates rockshaft. Not a real difficult fix on my tractors, but your's could be different. Have a service manual? There is a safety valve for 3 pt, but you are in effect dropping a tractor on your hitch arms if you rocking and front wheels come off ground. The safety valves aren't designed for shock load. Next time try a chain over a large tire rim for fulcrum and the drawbar.
   / L2950 - Broke 3PH Lift while stump-pulling #6
</font><font color="blue" class="small">( ...Whenever pulling heavy loads I always use the drawbar since it puts the load below the rear axle and it less likely to break.)</font>
And the stuff that can break there is gonna be way less expensive than the stuff inside the tractor!!! /forums/images/graemlins/shocked.gif
</font><font color="blue" class="small">( Sorry that you are having problems with your rig. /forums/images/graemlins/frown.gif )</font>
Same here. /forums/images/graemlins/frown.gif
Portable Restroom (A54865)
Portable Restroom...
Heavy Duty 10,000lbs Two Post Car Lift (New/Unused) (A59225)
Heavy Duty...
Computerized Wheel Balancer (New/Unused) (A59225)
Computerized Wheel...
2007 Honda CR-V SUV (A56859)
2007 Honda CR-V...
2014 BMW 320i Sedan (A55758)
2014 BMW 320i...
FENCE PANELS (A58214)
