L2900 key stopped killing tractor
   / L2900 key stopped killing tractor #1
mkmiller
Arkansas
Kubota L2900 4wd w/loader
I have a l2900 And I have always used the key to kill the tractor when I am done working. Recently the key stopped working to kill the tractor and I had to use the kill switch. With the key on the glow plugs do not work and neither does the gas gauge, all of this started at the same time. Any ideas? I致e checked all the fuses I could find and they are good. Thanks, Matthew
   / L2900 key stopped killing tractor #2
Appearances can be decieveing when checking fuses. Most shade trees pull fuse for better view,lazy pups like me use a volt meter or test light. Turn key on then touch probes to apposite ends of each fuse. No light or volt reading = fuse ok,light glow or voltage reading = bad fuse. If no bad fuses are sound after a closer look,post back and we can wade in deeper.
NEW Landhonor 9200LB Ratchet Binders & G70 Chains (A59000)
NEW Landhonor...
New/Unused CFG Industrial QK18R Mini Excavator (A57453)
New/Unused CFG...
2016 HYUNDAI Veloster Hatchback (A56859)
2016 HYUNDAI...
1969 VOLKSWAGEN BUG (A58018)
1969 VOLKSWAGEN...
METAL STORAGE CABINET (A58374)
METAL STORAGE...
2013 Ford F-250 Super Duty Service Truck, VIN: 1FT7X2BT7DEB91437, Extended Cab, 4x4, 6.7 L Power (A59076)
2013 Ford F-250...
