L2900 key stopped killing tractor
   / L2900 key stopped killing tractor #1
mkmiller
Arkansas
Kubota L2900 4wd w/loader
I have a l2900 And I have always used the key to kill the tractor when I am done working. Recently the key stopped working to kill the tractor and I had to use the kill switch. With the key on the glow plugs do not work and neither does the gas gauge, all of this started at the same time. Any ideas? I致e checked all the fuses I could find and they are good. Thanks, Matthew
   / L2900 key stopped killing tractor #2
Appearances can be decieveing when checking fuses. Most shade trees pull fuse for better view,lazy pups like me use a volt meter or test light. Turn key on then touch probes to apposite ends of each fuse. No light or volt reading = fuse ok,light glow or voltage reading = bad fuse. If no bad fuses are sound after a closer look,post back and we can wade in deeper.
2025 K1912 UNUSED Metal Livestock Shed (A50860)
2025 K1912 UNUSED...
John Deere Gator UTV (A50860)
John Deere Gator...
Tandem Axle Rear Truck Frame (A48081)
Tandem Axle Rear...
2020 John Deere 9520R Tractor (A50860)
2020 John Deere...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
2025 K2030 UNUSED Metal Garage (A50860)
2025 K2030 UNUSED...
