l2900 engine
/ l2900 engine #1
dkshooter
found out the hard way the other day that the manual is incorrect on the oil capacity. now I am looking for a replacement engine can anyone tell me what model/size options I have for the exchange?
/ l2900 engine #2
There will be an engine number on the valve cover. A complete engine is going to cost some $$$ you might look at getting that one ebuilt. Did it run and lockup??
/ l2900 engine
no I did hear it go and shut down. think a rod went thru the bottom cause the oil drained right out.
/ l2900 engine #4
Regardless what a manual would state as the oil capacity ... do you not use the dip stick to verify the correct oil level? KennyV
/ l2900 engine #5
did you overfill it or underfill it?--------------
/ l2900 engine
I underfilled it and it did read on the dipstick. pulling it right now but still unable to locate any numbers on the valve cover or anywhere else?
/ l2900 engine
I found a number on the fromt of the motor on the pully D1403 is there any other size motor that will interchange with it?
/ l2900 engine #8
I'm confused, how much did you underfill it? I can't imagine underfilling it a quart or two would ruin the motor. If it was a 14 quart system and you put in four quarts, I could see blowing the motor. How many did it hold and how many did you put in? Not trying to beat a dead horse, just trying to learn.
As far as engine swap, check with Kubota. I would think they could help. It could be a larger or smaller engine would bolt in. I know from working on cars, and I assume tractors are similar, that it is not just how the engine bolts in and mounts but how accesiories mount, how the engine mounts to the transmission, where the radiator hoses are etc. I don't know how much Kubota changed this kind of stuff over the years, so it could be you have a wide open choice of different year engines or it could be you are limited.
/ l2900 engine
Sorry for the miss information guys. Talking to my employees the problem seems to be there was too much oil. Seems as though a miss communication between 2 of the guys is that they both added the oil ending up with at least 11-12 quarts!
Sorry bout that.
/ l2900 engine #10
I can see that happening. If you got way to much oil in, and then it got up in the top of the pistons, wham. Thats one problem with diesels, they are such high compression that there isn't any room for fluid on top of the pistons.
/ l2900 engine
So is there any other motors that will fit in my tractor? i.e. D 1503
/ l2900 engine #12
Yes there are...
so now I am confused by your original statement in your first post, "found out the hard way the other day that the manual is incorrect on the oil capacity."
What did the manual state that was incorrect? KennyV
/ l2900 engine
Sorry I was misinformed my employees both addedd oil after an oil change so it was my fault :(
/ l2900 engine #14
FWIW...
Don't know where you're located but I just ran across this on Craigs List
I have a kubota diesel engine for sale. Its 24 hp and 3 cyclinders. It runs great and is in good codition. Always keep in a shed. $1000
Kubota Diesel Engine
it's in Rome GA...north of Atlanta
/ l2900 engine
But will it fit?? I am in Iowa but shipping is no problem. thanks
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Peterbilt 567...
UNUSED WOLVERINE R-31-G1.5T 1R RIPPER (A62131)
UNUSED WOLVERINE...
2018 Kenworth W900 Ext. Day Cab (A62613)
2018 Kenworth W900...
2012 Sun Coast Trailers T/A 12ft Enclosed Trailer (A61569)
2012 Sun Coast...
New/Unused Landhonor 50 Ton Capacity Hydraulic Shop Press (A61166)
New/Unused...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61568)
2022 Mac Trailers...
