L2850 won't start until it cools down
   / L2850 won't start until it cools down #1
banjerpicker
My L2850 will not start up until I let it sit for at least 30 to 45 minutes after I have been working it hard for an hour or two. Yesterday after tedding hay for two hours it would not start until it had been sitting for 45 minutes, then it was fine. This morning it fired up right away.
Each time dash lights come on and head lights are bright but it will not even attempt to turn over until it sits a while. This is the third time I have noticed this. The last time was when I had been moving a manure pile one bucket at a time to a small spreader in another file for about an hour.
Do you guys have any suggestions as to what might be causing this? It is not running hot on the gauge on the dash. New water pump about a month ago.
Thanks Larry
   / L2850 won't start until it cools down #2
Help us out a bit. By not starting do you mean not firing up? Or, not even turning the starter over?
   / L2850 won't start until it cools down #3
Just an initial guess,your "heat soaked"starter motor may be at the end of it's service life,worn brushes,etc.Post back.Good Luck!
   / L2850 won't start until it cools down #4
That sounds like an interlock switch. Seat, PTO, pedal, clutch. If not one of those then I suppose it could be the circuit card. Try wiggling some things.
It will not turn over one time until it cools down.
Great banjo in the video. Is that you playing?
   / L2850 won't start until it cools down #6
Number two on number two. Typical of a heat soaked starter.
Well I finally had time to check on my problem. I did a battery test and found 10volts under load. Not a bad battery but a weak one. It seemed to not have the energy to refire the tractor when it was hotter. I replaced the battery and checked the restart after tedding for two hours. It fired back up no problem. I am raking to day and if it works again I will consider...problem solved
Stay tuned
Larry
   / L2850 won't start until it cools down #8
Thanks for posting back.It's always interesting to hear the problem is repaired.Helps everyone learn.
Still working fine
Thanks for your input
Larry
EVERYTHING SOLD AS-IS WHERE IS!! (A50774)
EVERYTHING SOLD...
2001 GMC W4 CRANE TRUCK (A51222)
2001 GMC W4 CRANE...
ASSET DESCRIPTIONS & CONDITION (A52141)
ASSET DESCRIPTIONS...
2017 Buick Encore SUV (A50324)
2017 Buick Encore...
2003 JOHN DEERE 350D OFF ROAD DUMP (A51242)
2003 JOHN DEERE...
2020 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
