L2850 Tachometer Repair
   / L2850 Tachometer Repair #1
Popster
Bronze Member
Southern Maryland
Kubota L2850, 8N
My L2850 tachometer is not working. At high rpms it barely bounces off of zero. The hour meter is working.
Does the tach cable drive both the hour meter and tach?
Any thoughts on repairs?
Many thanks for any help!
Add: it is a mechanical tach- I see the replacement tach cable in the manual.
Oops, just saw the answer to my question in another post. Thanks.
   / L2850 Tachometer Repair #4
Don't know how the tach works on your tractor.
Mine is electronic off of the alternator. I had the RPMs goofing up so I removed the connector at the alternator and cleaned the corrosion that was starting in there.
But, like I said, don't know how the L2850 is set up.
   / L2850 Tachometer Repair #5
Thank you Deano, I'll check it.
2021 Delta Redirective Crash Cushion 75000 (A49461)
2021 Delta...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2015 GMC Arcadia SUV (A50324)
2015 GMC Arcadia...
2011 KOMATSU PC130-8 EXCAVATOR (A50854)
2011 KOMATSU...
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A48082)
2019 Club Car...
2011 FREIGHTLINER CORONADO (A50854)
2011 FREIGHTLINER...
