l2800HST
   / l2800HST #1
JwfL2800HST
Kubota L2800HST
Dash throttle won’t move. Linkage seems ok
   / l2800HST #2
Was L2800 under cover?
Have you spray some lube?
   / l2800HST
Thanks for the reply. The really bad weather we’ve had the past month must have rally done a number on the gizmo to which the linkage is connected under the dash.Today I loosened the fitting up and sprayed a LOT of Penetrating oil on it. Waited 30 minutes, and it’s now cured!! Thanks for the advice!
   / l2800HST #4
Also had L2800HST and notice it also getting harder to move,spray joints twice year with WD40 and bingo. :)
Not sure how many hours on L2800 if HST,if notice when stepping down on pedal to go forward and seems sluggish good chance rubber hose has crack etc. in vacuum line,our late L2800HST vacuum line was located under right step and wasn't hard to change.
LAMAR 20 T/A TRASH TRAILER (A50854)
LAMAR 20 T/A TRASH...
2011 Ford Transit Connect XLT (A50323)
2011 Ford Transit...
2006 GENIE GTH6622 TELESCOPIC FORKLIFT (A51242)
2006 GENIE GTH6622...
UTV (A49461)
UTV (A49461)
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2015 FORD F750 BOX TRUCK (A51219)
2015 FORD F750 BOX...
