L2800..that notorious hose...
   / L2800..that notorious hose... #1
Kenneth in Texas
Pretty good ways from DFW, Texas
Kubota L2800 4wd, FEL
down by the brake pedal that cracks and sucks air. Man that thing is expensive, cant I just use a hose that diameter and be fine long as long it doesnt have any kinks in it?
   / L2800..that notorious hose... #2
As long as its made for hydraulic suction line.
Not sure, but I dont think radiator hose is good for hyd oil, and I think its too soft and would collapse.
And its got some tight bends, if you can get some pre-bent suction line you'd be good. But it was a common issue, and the new hose dont have the cracking issue. So my vote, just get the OEM one and be done for good
   / L2800..that notorious hose... #3
I thought the replacement hoses are "better built" and last longer, I might be wrong... I know mine is lasting. I thought mine was $23 or so, yea not cheap.
   / L2800..that notorious hose... #4
I put one in stock and I'm waiting for the original to fail or look bad. I think it was just over $20. 2005 at 510 hours.
   / L2800..that notorious hose... #5
New hoses will not crack like the older originals. The cracking was caused by the hoses being put in place before the engine was painted. The hose was compromised by the painting and heated drying process. Kubota fixed that process at the factory (stopped installing the hose before painting/drying) and new hose or course are not subjected to the issue. I would suggest sticking with OEM if you need a replacement. Doubt you would ever need to replace it again.
   / L2800..that notorious hose... #6
I had a spare for my 2010 L3400hst. But the original never failed, and I sold the spare to someone on the forum.
   / L2800..that notorious hose... #8
You'll probably need it now that it's gone.:D:D
2025 CFG Industrial QK18R (A50123)
2025 CFG...
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
2005 JLG E300AJP TELESCOPIC MANLIFT (A51246)
2005 JLG E300AJP...
(APPROX 50) 2" X 2" X 98" TUBING (A51247)
(APPROX 50) 2" X...
HYSTER S50FT STRAIGHT MAST FORKLIFT (A51246)
HYSTER S50FT...
706075 LOT IDENTIFIER 43 (A53084)
706075 LOT...
