Oil & Fuel L2601DT Transmission oil level
   / L2601DT Transmission oil level #1
Micg
Help!
Can somebody inform me where is the transmission level gauge of the L2601DT Kubota? How much oil must be put in the transmission to have correct level?
Does this machine has any domestic version?
Thanks in advance for any help
Micg
   / L2601DT Transmission oil level #2
There is usually a dipstick on top of the transmission near the shifter. The top may look like a rubber plug. Don't know of crossovers or capacity.
Eugene
m8,
thnaks for your input.
Unfortunately cannot find this rubber plug dipstick on the machine. It has no sight glass either and the tranny oil is just under the upper shaft when the big gearbox cap is opened.
Any help is appreciated.
10x
   / L2601DT Transmission oil level #4
Check on the back of the rear end housing for a plug about halfway up.
Eugene
   / L2601DT Transmission oil level #5
Check plug should be on left side of trans housing by clutch pedal about halfway up side of housing.13mm head.Fill til it comes out of this opening.
RoGator RG1100C (A52128)
RoGator RG1100C...
1991 KALYN SIEBERT 60 TON LOWBOY TRAILER (A51243)
1991 KALYN SIEBERT...
John Deere GP Tractor (A50514)
John Deere GP...
2019 TAKEUCHI TL8 SKID STEER (A51242)
2019 TAKEUCHI TL8...
3 PHASE SEPARATOR (A52472)
3 PHASE SEPARATOR...
Livestock Stall Fan Cage (A50515)
Livestock Stall...
