L2600 Trans/Hydro Fill Question
   / L2600 Trans/Hydro Fill Question #1
TX Ags
Kubota L2600
Hello, I just bought a L2600 and I'm going to change the trans fluid. This is my first Kubota...the manual shows 4 drain plug locations. It also shows two fill locations: one in front of the seat (on top of the trans) and one behind the seat. I assume its a "common reservoir" so can I can fill it from either location? Or do I need to fill both locations? Its a DT transmission. Thanks for the help.
   / L2600 Trans/Hydro Fill Question #2
Pretty much all CUTs have a common hydrauluc sump in the transmission housing & use hydraulic fluid to lubricate the transmission. There are multiple low spots. Usually 2 in the final drives on the axles & usually 1 or 2 in the middle of the transmission. Fill wherever is easiest, as long as they all go into the common sump.
196046 (A50459)
196046 (A50459)
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
2014 INTERNATIONAL MA025 26FT NON CDL BOX TRUCK (A51222)
2014 INTERNATIONAL...
2016 Ford Escape 4x4 SUV (A50324)
2016 Ford Escape...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A51219)
2012 INTERNATIONAL...
2005 JOHN DEERE 5205 TRACTOR (A51222)
2005 JOHN DEERE...
