L2550, no start without help, but will run
   / L2550, no start without help, but will run #1
Groo
Platinum Member
I am thinking some start fuel boost feature on the pump not working. Any idea on where to look?
To be more specific; it starts with ether, but just cranking over without, it doesn't even smoke. Once started it will run on its own.
This is a sudden onset problem.
Is there an automatic enrichment or something?
   / L2550, no start without help, but will run #3
I have 5600 hours on my 2550 and never experienced this. Is the compression good and is it cranking fast enough to build heat?
Dug into it a little more
The fuel cutoff wasn't returning fully. Think I'll order a new solenoid and a new plastic lever the solenoid was dead a couple of years. Using the fuel cutoff knob seams to have worn the plastic lever.
   / L2550, no start without help, but will run #5
Why do you think it ran after the use of ether but on its own no go?
2021 Doyle 8 Ton Trailer Tender (A51039)
2021 Doyle 8 Ton...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A50397)
2024 BCL...
2013 MACK CHU613 (A50854)
2013 MACK CHU613...
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
2010 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A50854)
2010 TROXELL...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
