L2550 Hood Side Panels
   / L2550 Hood Side Panels #1
BFET529
Fowlerville, Michigan
Kubota L2550, Belarus 250AS, John Deere 6X4 Gator
I have a 88' Kubota L2550, but have only the right side hood panel... which is a little beat up and doesn't fit completely correct on the top ridge. Does anyone have an idea as to where I could find a couple side panels, preferably used?? Also, if my only option is to buy new, would they fit the 88 year model?
Thanks for your help!
Thanks Kennyv! I've put a request in to West Kentucky Tractor Parts to see if they have what I am looking for... I'll be doing some searching closer to here for a salvage as well...
Thanks for the info!
Thanks! I'll give them a try too!
   / L2550 Hood Side Panels #7
you could try sheet metal worker, would probably be cheaper than new ones if you could get them.
2018 XCMG XE210CU CRAWLER EXCAVATOR (A52576)
2018 XCMG XE210CU...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
12ft Godwin Dump Body/Bed (A51573)
12ft Godwin Dump...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Quick Attach Skid Steer Plate (A51573)
Quick Attach Skid...
