L2501 position control lever tension
   / L2501 position control lever tension #1
ipwanab
Southern Indiana
Kubota Grand L3560
Guys;
I have been unable to find results of lever tension adjustment on PTO lever. I have a damaged right shoulder and I need to loosen it for easier manipulation. Everything works great but lever takes about (guessing) 10 pond to move. It is not notchy or anything just tight. Throttle is the same but I think I can handle that. I am contemplating cruise control any opinions.
   / L2501 position control lever tension #2
The throttle can be loosened up by backing the two nuts under the dash. Don’t get it too loose or the throttle will reduce speed by itself. Took me a few tries until it suited me.
I busted my right wrist a while ago and found the factory set throttle to be problematic.
   / L2501 position control lever tension #3
Are you talking about the three point lift lever?
   / L2501 position control lever tension #4
ipwanab;5782424...lever tension adjustment on PTO lever...[/QUOTE said:
To engage the PTO or to Lift the 3 point hitch?
As for the cruise control, I have it on my tractor but rarely use it (or even think about using it). I don't mind using my foot on the HST pedal.
   / L2501 position control lever tension #5
On my L2501 the PTO became very hard to move. The upper lever is attached by a cable to the lower level. Mine began to bind up and it was cured by PB Blaster on both levers and some add to the cable itself. Work it back and forth and see if that makes enough improvement to help you.
   / L2501 position control lever tension #6
Had to do the same thing to my old L3200. Only some minor engine tweaks between the L3200 & L2501.
   / L2501 position control lever tension #7
Guys;
Which lever is it, PTO or position control?
2018 LAYMOR SM450-ST SWEEPER (A51242)
2018 LAYMOR...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
Unused 2025 CFG MX50R Mini Excavator (A49461)
Unused 2025 CFG...
2019 GEHL RT105 SKID STEER (A51242)
2019 GEHL RT105...
(2) 500 GAL WATER TANKS (A50854)
(2) 500 GAL WATER...
2012 CATERPILLAR 259B3 SKID STEER (A51242)
2012 CATERPILLAR...
