Oil & Fuel L2501 Gas station Diesel
   / L2501 Gas station Diesel #1
lootiejay
Clinton, North Carolina
Kubota L2501 HST
So this morning I was at the local Gas station filling up my Gas Cans with dielsel for my new Tractor. My neighbor pulls up and says, "You better not be putting that in your Kubota unless you want to tear up the engine." I asked if he was serious and he said yes. Then the guy at the pump next to me says it doesn't really matter which type of diesel you use in the tractor - just don't use off road diesel in your truck.
Here I am sitting outside wondering if it is safe to put these 10 gallons in my tractor, or if I just picked up some fuel for my next burn pile. Is anyone able to clear this up for me? If there is somewhere else I should look for the answer I will gladly read it.
Thanks!
   / L2501 Gas station Diesel #2
Thanks!
Well....if you can't use that diesel then what diesel are you supposed to use? Diesel is diesel. The only reason you can't use off-road diesel in a truck is because big brother wants his highway taxes and off-road is dyed so inspectors know the taxes haven't been paid on it. Other than the dye, there's no difference.
   / L2501 Gas station Diesel #3
On road diesel can be used in any diesel engine. I've used it for years in my Kubota powered bobcat when it is not convenient to get the offroad fuel. I do prefer the red fuel because of cost.
   / L2501 Gas station Diesel #4
Your neighbor is misinformed.
Yes you can run road diesel from a pump in your tractor. That is all I run because the off road stuff is not convenient here.
You can also run biodiesel, heating oil, transmission fluid, propane , natural gas, and vegetable oil. However most of these require special procedures.
Diesel straight from the pump is the safest and most convenient.
   / L2501 Gas station Diesel #5
Once a year I make a pilgrimage up to diesel mountain and after making a suitable offering I am allowed to purchase 1000 gallons of super mega ultra pure diesel with only .00000001 ppm of sulfur and I only use that in my tractor!!!!! Some people refer to it as Exxon
Wow, thanks for all the immediate answers. I feel kind of stupid asking this stuff but I really do not want to tear things up either. I feel like a little kid with all of this so the well reasoned responses are greatly appreciated.
   / L2501 Gas station Diesel #7
Tell your neighbor to join TBN so we can set him straight!
   / L2501 Gas station Diesel #8
lootiejay or anyone else with a newer tractor...
What is the minimum diesel cetane rating called out in the owners manual?
For years the manual called out 45 minimum when it wasn't possible to purchase that grade of fuel (At least in my area). The only thing I ever see listed in the past 10 years on the pumps is "Minimum 40 Cetane".
Not really worried about it, just curious what's published.
According to my manual it says "Cetane number of 45 is minimum. Cetane number greater than 50 is preferred, especially for temperatures below
-20 (-4 ) or elevations above 1500 m (5000 ft)
   / L2501 Gas station Diesel #10
Thanks!
Can anyone buy diesel with this rating in the US?
Kubota SVL95-2 High Flow Cab Skid Steer (A53472)
Kubota SVL95-2...
2016 John Deere 7210R MFWD Tractor (A53342)
2016 John Deere...
1991 Ford LNT9000 Roll Off Truck, VIN # 1FDYW90L5MVA15646 (A51572)
1991 Ford LNT9000...
2018 CASE IH 110N LOT NUMBER 223 (A53084)
2018 CASE IH 110N...
WEILER B670 FELLER BUNCHER (A51246)
WEILER B670 FELLER...
