L2501 backhoe
   / L2501 backhoe #11
Sounds like crap to me. I can see bypassing the 3pt as you can't use it with the hoe on, but not the loader. Every backhoe I've ever used needed the bucket to be lowered for proper stability while digging. Sounds like they plumbed things in wrong.
Agree, on rereading the ops initial post, he did tell dealer it was unacceptable, take it back and correct, so his instincts were correct and direct. Good call.
As pointed out, use of 3pt is the conflict with hoe and there is probably a thumb screw to lock 3pt control in disengaged position so you can't accidentally bump it to engage with hoe attached.
Please post follow up with dealer resolution.
   / L2501 backhoe
I appreciate all the replys it's good to know that it's doable an I will be able to use the bh77, grapple, and loader without having to disconnect and reconnect anything . Thanks again maxl
Toro z turn (A56859)
2017 Freightliner MT55 Step Van (A56858)
2017 Freightliner...
Yamaha Y280 Dirt Bike (A57149)
Yamaha Y280 Dirt...
2005 Freightliner M2 106 Ambulance (A56858)
2005 Freightliner...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
UNUSED JCT 72" HYD 4N1 BUCKET (A58376)
UNUSED JCT 72" HYD...
