L2500DT Wheel Seal Replacement
   / L2500DT Wheel Seal Replacement #1
theoldmanb
My recently acquired L2500DT has a leak that results in gear lube running down the side of the axle case on the right front side. In researching the problem, it appears that the leak is coming from the front axle seal.
I have purchased a new axle seal, but when attempting to install it, I can only locate the two lower snap rings that hold the assembly together. The parts diagram show a snap ring that holds the top bearing and axle case to the bevel gear case, but it is not visible or accessible from either the bottom or the side of the front axle case.
Does anyone have an idea of where this snap ring is located and how to access it for removal and subsequent installation?
1043 (A50459)
1043 (A50459)
2015 CAT 573c Fellerbuncher Cutter (A48836)
2015 CAT 573c...
FUEL TANK (A50854)
FUEL TANK (A50854)
Komatsu PC490LC-11 Hydraulic Excavator (A49346)
Komatsu PC490LC-11...
1999 INTERNATIONAL PAYSTAR 5000 TANDEM AXLE DUMP TRUCK (A51222)
1999 INTERNATIONAL...
2018 Terex RL4 4000W Towable Light Tower (A49461)
2018 Terex RL4...
