l2500 hyd oil change ques
/ l2500 hyd oil change ques #1
jimbo64
found the three drain plugs for the hydraulic fluid and my book shows two fill ports-one by the gearshift lever-other behind the seat-[not sure about this one and how one tells when these rear cavities have been filled sufficently] front cavity has a sight glass------anyone done one of these-don't want to overfill or underfill------thanks for any info
just talked to a dealer and he said one can use either one of the fill ports- odd but we'll check it closely-- interesting
/ l2500 hyd oil change ques #3
Hello
On my l2500 between the rear end and the gear case in side there is a hole between the two that let's fluid run from back to front.
Only reason I know is I rebuilt a wreaked L2500DT tractor if your not sure you can use a brazing rod to check the gear case.
Hope this helps Carl
Hello
thats kinda what the dealer alluded to ----said filling through either would fill the other one---wonder why the "two" fill ports though-
STARTRITE H325 HEAVY DUTY HORIZONTAL BAND SAW (A64280)
STARTRITE H325...
(7) DONALDSON P600676 AIR FILTERS (A64276)
(7) DONALDSON...
Caterpillar D5H Series 1 and 2 Dozer Service and Parts Manuals (A63117)
Caterpillar D5H...
2022 John Deere 6R 130 Tractor (A63111)
2022 John Deere 6R...
MOULINE 260 BAGEL SLICER (A64281)
MOULINE 260 BAGEL...
(1) UNUSED 12" RUBBER TRACK (A64280)
(1) UNUSED 12"...
