l2500 hyd oil change ques
/ l2500 hyd oil change ques #1
jimbo64
found the three drain plugs for the hydraulic fluid and my book shows two fill ports-one by the gearshift lever-other behind the seat-[not sure about this one and how one tells when these rear cavities have been filled sufficently] front cavity has a sight glass------anyone done one of these-don't want to overfill or underfill------thanks for any info
just talked to a dealer and he said one can use either one of the fill ports- odd but we'll check it closely-- interesting
/ l2500 hyd oil change ques #3
Hello
On my l2500 between the rear end and the gear case in side there is a hole between the two that let's fluid run from back to front.
Only reason I know is I rebuilt a wreaked L2500DT tractor if your not sure you can use a brazing rod to check the gear case.
Hope this helps Carl
Hello
thats kinda what the dealer alluded to ----said filling through either would fill the other one---wonder why the "two" fill ports though-
APPROX (80) PIECES OF 48" X 56" EXPANDED METAL (A64280)
APPROX (80) PIECES...
1000 Gal Tank (A64119)
UNUSED AGT MX CRT23 STAND-ON SKID STEER (A64280)
UNUSED AGT MX...
2019 Peterbilt 567 Quint Dump (A62613)
2019 Peterbilt 567...
UNUSED WOLVERINE HYD SCREENING BUCKET (A64281)
UNUSED WOLVERINE...
Ford Pickup Truck Bed (A61573)
Ford Pickup Truck...
