L245DT Spec's
/ L245DT Spec's #1
Anonymous Poster
Epic Contributor
L245DT Spec\'s
I'm looking for the spec's on 1984 L245DT.
Engine HP 25?
PTO HP
Lift capacity of the 3PTH
Lift capacity of the loader
I've searched the archives and was not able to find the information.
Thanks,
Frank
/ L245DT Spec's #2
Re: L245DT Spec\'s
Try Yesterdays Tractor Web Site. They have a lot of specs for previously built tractors. Zimmerer Kubota also has a little information concerning HP and year of manufacturer.
/ L245DT Spec's
Re: L245DT Spec\'s
Thanks for the pointer. I checked Zimmerer Kubota was able to find that the PTO HP = 22..
Would still like to know the lift capacity of the :
Loader
3PTH
Thanks,
Frank
/ L245DT Spec's #4
Re: L245DT Spec\'s
Glad that helped. You can tell pretty well by the bucket size. A 6 ft bucket holds about 3/4 yard and weights about 2200 pounds heaping with sand. 5 ft bucket holds about 1/2 as much and heaping is around 1200# or so. Not sure about 4 ft bucket but probably holds around 700#.
/ L245DT Spec's #6
Re: L245DT Spec\'s
I guess dirt pretty close. /w3tcompact/icons/smile.gif
/ L245DT Spec's
Re: L245DT Spec\'s
Well I just received a copy of the L245DT operators manual from Jensales.
PTO HP = 22
3PT Max lift = As listed in the implement list.
rear rotary mower = 550 lbs.
roto-tiller = 600 lbs.
No mention of loader in the manual...
Thanks to those who helped..
Frank
/ L245DT Spec's #9
Check Tractor Data.com
/ L245DT Spec's #11
22 years later, but better late than never...
I bought a 245dt 2 months ago and was looking for stuff in the forum and noticed your post. That website has every tractor I wanted to know about on it.
