Loader L245DT - FEL Auxiliary pump ?
   / L245DT - FEL Auxiliary pump ? #1
SHINTON
I have a Kubota L245dt ( SERIAL # l245DT-54980) That has an after market Front End Loader (FEL) on it. The FEL presently runs off the hydraulic pump with the 3pt hitch. That system is fast enough and strong enough, but using it that way causes the pump to wear out too fast, and they are expensive.
SO, I am looking for an alternative way to run the FEL. There is a splined shaft coming out the front of the motor (about 1 inch in diameter and with about 18-20 splines), can a hydraulic pump be added there,
OR is there a 12volt electric over hydraulic system that would work
OR does anyone have any other ideas???
Thanks in advance!!!
Sam Jr & Senior!
   / L245DT - FEL Auxiliary pump ? #2
My tractor uses a front crankshaft driven pump for the loader, so I have 2 pumps.
My buddy B7100 is equipped that way also.
I gather the practice is quite common on after market FEL installationsè
The main criteria would be to couple with a U-joint or flex of some sort otherwise misalignment could damage front crank main bearing.
Also dont go too much larger than origional factory pump otherwise your engine might want to surge or lug.
2004 Dodge Ram 1500 4x4 SLT Crew Cab Pickup Truck (A50323)
2004 Dodge Ram...
3pt. Bush Hog Mower - RD TH72 Finish Mower (A50514)
3pt. Bush Hog...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2021 Toyota Corolla LE (A50324)
2021 Toyota...
2006 John Deere 650J LGP Crawler Tractor Dozer (A50322)
2006 John Deere...
2022 CATERPILLAR D4 LGP CRAWLER DOZER (A51242)
2022 CATERPILLAR...
