L185?
/ L185? #1
Anonymous Poster
Epic Contributor
Can anyone give me info on this tractor, dealer has a 2wd diesel with 1500 hrs with mower deck for $1800, tractor appears in good shape but dealer does not know much about it. Can anyone fill me in on these, what are the specs, what are the weak areas etc, all i want it for is mowing about 3 acres of grass, have other large tractors for big work, thank you
/ L185?
Kubota L185, Mfr. 1977-83, 45 cid-2cyl, 15.4 PTO hp, 8/2 spd, 1727 lbs., Last Fact. Price $5,270.
That would be a going price around here at the auctions... {$1200-2000 w/mower}
/ L185? #3
I have an L185 and so far it has been a good tractor for me. It's a mid 70's with ~700hrs. About 70 of those hours are mine. I also have a Kubota 60" mower deck that is very stout.
I don't have my manual here at work, but I think it's about 15hp at the pto. It weighs about 2000lbs with the deck. 4sp gearbox with a Hi/Lo range. 3 spd PTO, 540 750 1000rpm. Not sure what the 3pt capacity is but I use a beefy 3pt 5' disk that is loaded with extra weight and it lifts that okay.
They seem to be a good, stout, basic tractor. And you will be amazed at how little fuel it uses.
Things to look for.... they do not have a water pump, water circulates via convection flow. So the cooling system must be kept in top shape and when mowing you need to keep the screen on the radiator clean. Following those rules I have mowed in 100+ degree weather with no problems. Since it has no temp gauge, make sure the "whistle" on the overflow tube works.
Watch for gear oil coming from the shifter boots, it mean the gear case vent tube is plugged. Lift up the seat you will see a little tube shaped like a sideways "?" mark. Unscrew it and run a pipe cleaner thru it.
If the mower runs off a front pto examine it very carefully. The shaft extends off the front of the engine's crankshaft. Look for lateral play in the shaft and the electric clutch. (bad support bearing) I didn't and ended up paying ~$400 for a new shaft and clutch.
I had another problem with the kubota mower. The belt did not maintain the same tension as I raised and lowered it. It went from too tight to too loose. So I added a spring loaded belt tensioner to improve the performance. Works great.
Parts are still available for now.
I like mine and mow about a 1/2 acre of grass routinely. As long as the grass is not too long, it will mow in 2nd gear, hi range, pretty easily.
If you think it has been maintained and not abused....$1800 seems pretty reasonable and it will certainly do better/fast than a similar priced riding lawn mower.
Well I guess that's more than 2cents worth.
/ L185? #4
I'm with Chris here. I have an L1501 which is a grey copy. I have 2 low ranges = 16 forward speeds.
I slash (bush hog) about 3-4 acres no worries.
Yes ensure the radiator and screen are clean due to lack of water pump, and I also had the gearbox breather clog up with hornets mud.
But all in all they seem a good cheap tractor. When changing fuel filters you need to manually bleed the air from the pump by loosening the big screw. That caught me the first time.
Cheers
/ L185? #5
I've also heard that water finds it way into the steering gearbox and rusts the bearings. Check that too. I looked at an L1501DT with Woods mower once. $3000, but I just couldn't bring myself to buy a grey market tractor. I was worried about not being able to get parts. That was a year ago and I probably would have bought it today knowing what I now know.
/ L185? #6
Yes someone else on here mentioned the water in the steering box thing. I have never looked at mine.
Is there a way to check for water/drain the oil etc.?
Cheers
/ L185? #7
I have heard about the steering box thing too, but I keep forgeting to have a look at the thing. Tractor still steers okay so.......maybe it's not a problem??? Neil if I figure out how to check / drain / replace the steering box oil I will let you know. Of course being the forgetful procrastinator that I am, you may get to it first./w3tcompact/icons/grin.gif
/ L185?
Ditto the steering box thing, just replaced the one on my L175 to the tune of $550. Pulled the old one apart and there was nothing but water. Sounds like a good deal though.
2008 Freightliner Allegro Bay Class A Motorhome (A61574)
2008 Freightliner...
2008 Honda Civic Coupe (A64557)
2008 Honda Civic...
Soil-Max HD Cart (A64126)
Soil-Max HD Cart...
2013 Felling 25' x 102 Tag Trailer (A62613)
2013 Felling 25' x...
2016 MULTIQUIP DCA-25SS1U4F PORTABLE GENERATOR (A63276)
2016 MULTIQUIP...
John Deere 1025R (A62177)
John Deere 1025R...
