L185 Diff Lock
   / L185 Diff Lock #1
njrqs
Veteran Member
Queensland, Australia
Kubota L1-20 DT
The diff lock on my old L1501/L185 works OK but won't pop back off. It is apring loaded and should only work when pressed down.
But mine sticks on and I often have to reach down and pull it up with my hand.
Any ideas ??
Cheers
<font color=blue>Neil from OZ.</font color=blue> /w3tcompact/icons/smile.gif
   / L185 Diff Lock #2
Try spraying some penetrating oil around where the shaft goes into the trans case and work the pedal up and down. See if that frees it up.
   / L185 Diff Lock
Kubmech
So you don't expect there is any gear problem causing this, rather just a linkage ?
The linkage appears to right through the housing and pokes out the other side too.
Cheers
   / L185 Diff Lock #4
Neil, if the slippery stuff does'nt help, on the right side where the linkage attaches to the diff. lock rod that goes into the trans. housing you should see two flat pieces of spring steel. That's what returns the pedal. If they're broke or wore out just order: one 37150-2664-3 and one 37150-2666-0 and you should be like new.......Should be about 24.00 in OZ money..
   / L185 Diff Lock #5
neil; nice to have a kubmech around , ain't it. not only tells u what might be wrong with your tractor but also gives the part no.s. and the expected price!/w3tcompact/icons/smile.gif
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
2012 Honda Accord Sedan (A50324)
2012 Honda Accord...
1968 International Harvester 856D 2WD Tractor (A50657)
1968 International...
2021 FREIGHTLINER 126 SLEEPER TRUCK (A51222)
2021 FREIGHTLINER...
2018 KUBOTA SVL95-2S SKID STEER (A51242)
2018 KUBOTA...
