l1500
   / l1500 #1
Anonymous Poster
Epic Contributor
I JUST BOUGHT A KUBOTA 1500 TRACTOR. CAN ANY ON TELL ME HOW I WOULD FIND OUT THE YEAR IT WAS MADE? THE SERIAL NUMBER IS 51471, ALSO CAN I GET A SERVICE MANUAL FOR THE 1500 OR DO I JUST ORDER A L175 MANUAL.
THANKS ED
   / l1500 #2
Ed
I think they are around the early 80's.
I have an L1501 with a 4 speed PTO and a few other changes. Yours should be a 4 speed PTO but only 1 low range but I have 2 low ranges = 16 total forward gears.
I think L175 is OK. Over here the L185 is the match.
Not too much info on them but I think with L175 you can't go too far wrong.
Hope this helps.
Cheers
   / l1500
Thanks for the respones. I do have a high and low gear range that gives me 10 speeds.
   / l1500 #4
How do you get 10 speeds??
4 x 2 = 8 or am I missing something here???
Or do you count reverse.
Hey make sure you register if you want to stick around. Is much better !
Cheers
   / l1500
your right. I am new to the tractor world I think I will register.
LANESHARK LS3 LOT IDENTIFIER 148 (A53084)
LANESHARK LS3 LOT...
Spartan Pierce Foam Pumper Training Fire Truck (A51692)
Spartan Pierce...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A51248)
UNUSED WOLVERINE...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
DEWALT 3400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 3400 PSI...
2005 Freightliner M2 106 Dumpster Carrier Truck (A51692)
2005 Freightliner...
