Buying Advice L1500 Advice
   / L1500 Advice #1
Lawman17
Have an opportunity to buy a L1500 with bush hog and box blade for $1000. Tractor runs and pto and hydraulics work. Only problems are a single gear on the pto and transmission are stripped out. Gonna be used mostly for a deer lease maybe a little around the house. Would it be worth the money in your opinion?
   / L1500 Advice #2
The L1500 is a grey market L175 in the early days of Kubota, but the gears should be similar. You will not get much from a dealer as far as parts help - better to get the L175 manual and order parts if you intend to fix it. This should have the 2 speed PTO hi/lo and also a 4speed tranny with a hi/lo so 8 speeds total.
If you can run this in the "other" gears and the bush hog PTO and is 2WD @ $1000 its not a bad deal, if its a 4WD its worth a little more and a much better deal.
A little work and you could have a $2K tractor.
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
Case Maxxum 140 (A50120)
Case Maxxum 140...
2019 INTERNATIONAL LT625 (A52472)
2019 INTERNATIONAL...
FAE 150/540 LOT NUMBER 137 (A53084)
FAE 150/540 LOT...
2013 ISUZU NPR STAKE BODY TRUCK (A52577)
2013 ISUZU NPR...
