l100 and lt133 no starts
   / l100 and lt133 no starts #1
copperhead1967
greensburg PA
kubota BX22, Cub ZForce S 48 inch deck
Hi, I'm a Kubota forum poster but own a couple Deere mowers. My primary mower is the L100 w/ replaced engine, a briggs with a oil pump. so I guess it's a 110 or something. Anyways it will start if you jump the solenoid so I replaced the solenoid w a dealer replacement one. The new one has the battery and starter lugs top to bottom. the old one had them side to side. I installed it and the tractor still does the same thing. Is there a polarity on these battery cables or the smaller solenoid wires? Tractor runs fine once you jump the solenoid. Other weird thing is the reverse mow enable button has to be held in to keep the engine from cutting out when backing up. This just started after the solenoid swap. I also took the key switch out and popped it apart, cleaned the contacts and put it back together. It will shut down if you turn the key off and won't start when jumping solenoid w key off so I think key switch is good. Any thoughts?
Second machine is a project Lt133. Given to me by a buddy for parts.
It's a good machine with a bad first owner. Deck is about 95% new and tractor is in good shape overall. It sat for 2 or 3 years.
I changed oil and plug and cleaned it up some.
I replaced the starter as the last owner cooked it. It will crank the engine when the solenoid is jumped but no fire. The harness to the voltage regulator/rectifier is burnt on one of the end wires, the last owner again. I removed all the old fuel and last night and will check for spark and fuel pumping when cranked today. This machine has a series of relays behind the engine, are they all the same and what are the pin test for them w/ a ohm meter? I'm thinking the voltage pack is bad and caused the guy to crank it until he cooked the starter and burned up the wires.
Thoughts?
Probably should have done two post but if replying start w L100 or Lt133 on your replies. Thanks
Thanks
On the LT133 I have fuel to the carb. took it off and soaked it in gas. Emptied some crud in the bowl. Floats stuck a little but free once I cleaned it with carb and choke cleaner. On to the spark.
UPDATES ...LT133 Ended up being the start solenoid was bad too it would stay stuck in closed position and burnt up original owners starter. Interestingly enough the new solenoid is a different configuration. ( top to bottom for main battery connections) I placed the red wire with the blueish fusable link on it to the output side of the solenoid. It was still acting goofy and would not start unless I bypassed the key switch. After some readings it dawned on me the blue fused/red wires provide the 12V to the start switch so they should be hooked to the input or "always hot" side of the solenoid. (I was OHMing out the solenoid and found a short from the neg BAtt post to the solenoid output and removed the small blue fused /red wire and the short went away...so where does it go ....oh..... on the INPUT side.)
So now I'm zooming around the yard on the LT133...however NOW the deck is giving me fits. It won't go down after the initial lift from the fully down position using the lift lever when installing it. Also engine dies when I put the mower blades in gear. Just bought a new belt and will check pulley brakes next. I know the blade engage switch is good from earlier troubleshooting.
L100 is runnign fine but has a injured deck right now and needs some welding, tree root. It just decided to run right on its own since original post.
   / l100 and lt133 no starts #4
Well Glad you are getting it figured out.
2017 Ford F450 Service Truck (A55788)
2017 Ford F450...
2015 FREIGHTLINER CASCADIA DAYCAB (A53843)
2015 FREIGHTLINER...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A54757)
UNUSED WOLVERINE...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
UNUSED 10PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 10PCS...
