L series remote valves
   / L series remote valves #1
RichNJKubota
Hunterdon County, NJ
Kubota L4310HST
I need to get one remote valve kit for my L4310HST Kubota. I know this is expensive. Does anyone have any recomendations for the cheapest dealer?
I'll also be buying some other less expensive parts also.
Thanks,
Rich
NJ
   / L series remote valves #2
Try priceing the gearmore kit, 2 or 3 spool it should be cheaper, and its better to use, at least with a grader box. it mounts off of the ROPS, makes a good handrest
   / L series remote valves #3
You can probably find it darn cheap if you shop around and have someone UPS it to you. Only caveot is that they are not easy to install.
Thanks for the advice Neil!
The parts are on their way via UPS.
Rich
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
1994 INGERSOLL RAND SD100D PADFOOT ROLLER (A52706)
1994 INGERSOLL...
KUBOTA B26 TRACTOR BACKHOE (A52705)
KUBOTA B26 TRACTOR...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
2012 CATERPILLAR D6T XW HI-TRACK CRAWLER DOZER (A51406)
2012 CATERPILLAR...
Pair 2 - ST225/75R15 radial trailer (A55787)
Pair 2 -...
